I have a geoprocessing service that breaks because the server adds two strings to the data variables. The code snippet is:
dir_path = r'e:\ArcGISData\ForestEcosystemValuesData'
arcpy.AddMessage(dir_path)
# root = r'E:\ArcGISData\ForestEcosystemValuesData\ForestValuesApp.gdb'
workspace = os.path.join(dir_path, 'ForestValuesApp.gdb')
arcpy.env.workspace = workspace
CS = 30
CONV = 0.000247105381
ZONEFIELD = 'SAID'
AOITotalAreaAcres = 0
root = arcpy.env.workspace
urban = os.path.join(root, 'AOIUrbanVector')
rasterList = ['uBiodiversity', 'uClimate', 'uCultural', 'uEconomic', 'uHumanHealth', 'uWatershed', 'rBiodiversity', 'rClimate', 'rCultural', 'rWatershed']
tempPolygon = r'in_memory\temp1'
memo = "in_memory"
And when I open the script on the server folder I have this, it adds a string (a') to one of the variables and another string (db') to the other variable:
And this is the error returned on the app:
File "E:\arcgisserver\directories\arcgissystem\arcgisinput\ForestEcosystemValues\EcoNewGP.GPServer\extracted\p20\forestecosystemvaluesdata\LATEST_CHANGEURBANNOPARAMS CLEAN NO PARAMS3.py", line 5
g_ESRI_variable_1 = 'E:\\ArcGISData\\ForestEcosystemValuesData'a'
SyntaxError: invalid syntax
My coworkers are able to publish the geoprocessing service with no errors. What is going with my publishing? Thanks
This sounds like a known logged bug, BUG-000147516, which unfortunately doesn't help you immediately. It may be easiest to fix the replaced strings on the server, or as a workaround, construct your path variables all as os.path.join elements, and remove the one hiding inside of the comment.
Best wishes, Shaun
But how do you explain that it works on my coworkers computers, when they publish from theirs? It is the same code. How can I change the dir_path, in this case?
It may be that your coworkers are on different versions of the software, or there are specific circumstances where this bug is introduced that aren't universal, I haven't dug into it sufficiently to say. In terms of the path, could you try something like:
dir_path = os.path.join(r'E:\ArcGISData', 'ForestEcosystemValuesData')
If it persists as an issue despite 'hacks' like these, it may be worth seeing if using a different project location has any effect.
