How to remove downstream lines in ArcGIS pro?
830
01-31-2023 11:33 PM
AmirHosseinAhrari
Hi All,
I am working on watershed delineation and I need to remove downstream rivers based on their elevation compare to upstream and I am not sure which of geoprocessing tools in ArcGIS pro may help. Does anyone has any idea?
Thanks in advance,
jcarlson
I would imagine that there are some attributes on the river features to help. What does the schema look like?
If you have an elevation attribute on the lines, a Range Slider could do the trick. If there are other attributes that can reliably filter them out, then just a query definition. If your river features do not have these kinds of attributes, they could be calculated.
- Josh Carlson
Kendall County GIS
