How to merge tables at the end of an iteration?
2262
15
10-05-2018 05:28 AM
SerenaFraccascia
I am running a model iterating through N feature clases and I get N tables as output. The model works properly. Here it is:
I need to merge this tables into a new one, thus I would run my model as submodel. However, when I add it to the new model something goes wrong:
I am still learning modelling and programming skills, thus any help, suggestions, clarifications are more than welcome!
DuncanHornby
MVP Notable Contributor
Yes what is it set to?
SerenaFraccascia
It is the directory where the folder 'points' (see first fig in the original post) is located. I need the model to be the most general possible, as I have to share it with other colleagues.
DuncanHornby
OK I needed you to tell us this as from that screen shot it could have potentially been a file geodatabase workspace and you cannot have a ".dbf" at the end of a file geodatabase table.
Looking at the model it seems OK to me so all I can suggest is you replace the table name from 'out_stats_%N%.dbf' to 'out_stats_%Name%.dbf' where %Name% is coming from the iterator. I suggest this as I am guessing that %n% never increments with an iterator?
SerenaFraccascia
It seems it doesn't solve the problem. By the way %n% works fine when I run the first model alone.
DuncanHornby
OK I am all out of ideas I would need the data and model to solve this.
SerenaFraccascia
Thanks anyway! 😉
