How to interpolate values along a stream network
1263
04-15-2021 09:57 AM
BenjamenWetherill
New Contributor III
In ArcMap, is there a way to interpolate water quality values along a stream network?  I have values that were collected at stations in my stream network, and I would like to interpolate them between stations on connected streams.  I thought about using raster interpolation, but I don't want to interpolation to jump laterally across watersheds - just along the flow of water.  I would like to be able to use graduated coloring on the streams to show changes in water quality.
SteveLynch
SteveLynch
BenjamenWetherill
New Contributor III
Thanks.  I will try these.
BenjamenWetherill
New Contributor III
Spline with Barriers works perfectly!  If I draw a polygon barrier that follows the streams and separates lateral streams, and doesn't block direct lines between consecutive sampling points.  My license doesn't include Kernel with Barriers.
DuncanHornby
MVP Notable Contributor
Does that make sense? If you are sampling pollutants as a measure of quality won't they have "diffused" or  "gone downstream" by the next day? Interpolating specific pollutants would imply some sort of static distribution I guess?
BenjamenWetherill
New Contributor III
Yes, I would say it makes sense.  Rivers are not monolithic.  They receive pollutants at specific points and the pollutants get diluted or attenuated at other points.
