How to get field values from every feature, and place them in a comma seperated string?
3147
7
02-05-2016 10:45 PM
MichaelKowalczyk
New Contributor III
Hello, I have a modelbuilder tool with an iterator that produces a selection in another feature class each iteration.  I would like to get the value of a field from the records in each selection, and put them in a coma separated string.
I have attempted to use an embedded python tool to use a search cursor over these records, but it does not seem to work.  I get a runtime error: cannot open '<<field name>>'
Do you have any suggestions as to how to accomplish this?  Would a searchcursor work in an iterator model? Thank you.
My python tool containing the search cursor.  It works as expected in isolation, but not in the model builder tool.
import arcpy
from arcpy import env
env.workspace = arcpy.GetParameterAsText(0)
##import time
#from datetime import datetime
##current_time=time.strftime("%H:%M:%S")+" "+ time.strftime("%d/%m/%Y")
local_pairlist = "" #list will be populated with pair ids from paths in prevailing direction
#selected features
pathfc      = arcpy.GetParameterAsText(1)  #demand paths in prevailing direction
path_pair_id= str(arcpy.GetParameterAsText(2)) #pair id field
with arcpy.da.SearchCursor(pathfc,(path_pair_id,)) as path_cursor:
        newpair=path_row[0]
        if local_pairlist == "":
            local_pairlist+=newpair
        else:
            local_pairlist+=r","+newpair
    #--//colection loop--#
##print "OD Builder Finished!\n\nOutput table="+str(out_name)+"\n\nLocation: " + str(out_path)
arcpy.AddMessage("Subpairs saved!")
arcpy.SetParameter(3, local_pairlist)
WesMiller
Regular Contributor III
Yes a search cursor will work in a model with an iterator in it.
Here's a picture of the model i tested with:
Here's the code used:
import arcpy
#Variables
fc = arcpy.GetParameterAsText(0)
fld = arcpy.GetParameterAsText(1)
mystring = ""
with arcpy.da.SearchCursor(fc,fld) as cursor:
    for row in cursor:
        mystring += str(row[0]) +","
arcpy.AddMessage(mystring[:-1])
NeilAyres
I normally do more complex stuff like this in python.
So, could you show us your code?
MichaelKowalczyk
New Contributor III
I actually ended up rewriting the tool from scratch in Python, and actually got at least a 10 fold improvement in performance!
WesMiller
import arcpy
#Variables
mystring = ""
    for row in cursor:
MichaelKowalczyk
New Contributor III
Thank you, , for confirming that it should work.  My tool looked very much like yours.  However, I was getting an error that it could not open the specified field.  Do you have any suggestions?
WesMiller
Could you post the error you are getting. Have you confirmed the field name exists? Could you also post the model you are using
MichaelKowalczyk
New Contributor III
I was using an unwieldy model that I should have written in arcpy to begin with.  I actually managed to do so in a relatively quick manner, it works 10-100 x faster than model builder!  Troubleshooting it seems no longer necessary.
NeilAyres
Yes,
there have been other post here about the speed improvements once a task is coded using arcpy / python.
Good to see you have your solution.
