How to export Shapefile to CAD (DXF) and have the correct elevation value?
2989
12-16-2014 06:07 PM
TorikaWaqa
Whenever i export the contour shapefile and it turns out to have zero elevation level. Can someone show me how to get the correct elevation.
Thanks in advance,
Torika
DanPatterson_Retired
is it a 3D shapefile (polylinez) or a 2D one with Z-values in a field
TorikaWaqa
Its in 2D
MikeCusi
Occasional Contributor II
use the "ADD CAD fields" tool before the "Export to CAD".
MuhammadAttique
New Contributor III
Hi Torika Waqa
If you are sure with Z-Value in your shape file , then just to set an Environment setting before export to CAD , go to Environments Settings - Z Values - Output has Z values - click Enabled.
press OK -OK ,
You will definitely get the elevation in CAD.
MikeCusi
Use the Add CAD fields then populate the appropriate field before exporting to CAD
