how to derive (x,y) coordinates from distance and angle table of a known point?
983
07-23-2018 01:38 AM
OplkAdam
let's say i have a table that contains distances and angles from known point, and i want to extract the exact coordinates of the maximum distance to the associated angle of the same distance, how to do this in a GeoProcessing server?
DanPatterson_Retired
Sample data or table?  It would help to see what you have.
And more importantly, are you talking planar coordinates or geographic?
It is relatively easy to calculate the point coordinates given a distance and bearing/azimuth/angle from a start point.
Once that is accomplished then your distance filter can be applied to return the appropriate angle.
OplkAdam
Thank you
It's a table of a geographic coordinates, and sorry for not mentioning it
before, i want to run this process as an online service.
as i want to send GPS information from mobile phone to GeoProcessing server
for further processes
Thank you
So more levels of complication than anticipated....
I will flag Robert Scheitlin, GISP‌ to better redirect this question to a more appropriate location
OplkAdam
Yeah.. i thought it would be easier but turned a bit complicated. As i want
to preform the same process to retrive a point from different distances and
angles assigned to a set of points!!
Anyways thank you, i do value your input and yor extended help
