How to create a ModelBuilder in arcgis pro program that can export results into images format.
904
5
01-18-2021 03:14 AM
cinnaaaoo
How to create a ModelBuilder in arcgis pro program that can export results from point and line future classes Combine them into images format (e.g. .jpg, .png).
DanPatterson
If the tools that you would use don't exist in modelbuilder then you cant use modelbuilder unless you write a python script that you can use in modelbuilder.  And if you are going the script route you may as well develop a custom toolbox and use the script
Add a script tool—ArcGIS Pro | Documentation
... sort of retired...
DanPatterson
Convert Feature To Raster (Raster Analysis)—ArcGIS Pro | Documentation
Export or convert raster datasets—ArcGIS Pro | Documentation
Are at least two things to explore.
What have you looked already?
Have you tried it manually using the tools in ArcToolbox?  If so, replicate your workflow in Modelbuilder
cinnaaaoo
Thank you. I want to combine the two future classes into just one image. And the two tools you gave me But it was not successful. Do you have any other building?
DanPatterson
sounds like you want to export a map
lots of options but little use for modelbuilder in the workflow if that is your intent
Introduction to export a map or layout—ArcGIS Pro | Documentation
cinnaaaoo
About that, but I want to make it in a modelbuilder, what tools can I use?
DanPatterson
