How to convert State Plane to decimal degrees (and save to attribute table)
5443
02-25-2015 12:26 PM
AnneWynn
Any suggestions?  Thanks for the help!
TimWitt2
Anne,
Do you have a feature layer with attributes? If so, then you can add two fields , call them Lat and Long. Right click the heading of one of the Fields and choose "Calculate Geometry" in the unit dropdown box should be Decimal.
Tim
TimWitt2
Anne,
Tim
AnneWynn
Thank you, Tim!!
I really appreciate your help.
Anne
JoeBorgione
If you want your data to be in Decimal Degrees use the project tool.
If you want to simply keep track of the decimal degree coordinates of your UTM data, add two fields in your UTM data attribute table like Latitude and Longitude as double type.  The use the calculate geometry feature in an edit session setting the appropriate units.
AnneWynn
Thank you so much for your help!!
Appreciatively,
Anne
