Hi-It would seem that a good, scriptable approach for this would be with a list driven call in a Python script using "copy_managment()" method.I should be able to append the ".tif" to the output raster name, and get TIFFs.This is not my experience .... redundant print statements strongly indicate that the gp.Copy_Management call is getting the proper syntax, but I'm still getting only GRIDs on the other side.Any ideas? Kudos for the R-click batch converter tip! Daryl# ---------------------------------------------------------------------------
# Grids to Tiffs
# Created on: Fri Aug 20 2010 03:15:43 PM
# Daryl Van Dyke, USFWS Klamath SHC Analyst
# Import system modules
import sys, string, os, arcgisscripting
# Create the Geoprocessor object
gp = arcgisscripting.create(9.3)
# Check out any necessary licenses
gp.CheckOutExtension("spatial")
# Load required toolboxes...
gp.AddToolbox("C:/Program Files/ArcGIS/ArcToolbox/Toolboxes/Spatial Analyst Tools.tbx")
gp.OverwriteOutput = 1
# Local variables...
TileSet = "G:\\02_Shasta\\DEM_Tile\\"
targetDirectory = "J:\\DEM_tif\\"
gp.Workspace = TileSet
listRasters = gp.ListRasters( "", "")
print "Workspace: "+ TileSet
print listRasters
for rasters in listRasters:
print "copying "+rasters+" to "+targetDirectory+rasters+".tif"+" from "+TileSet
outputLocation = targetDirectory+rasters+".tif"
print outputLocation
print "gp.Copy_Management("+rasters+","+outputLocation+")"
gp.Copy_Management(rasters, outputLocation,"#","#","#","NONE","NONE","#")
example print output:J:\DEM_tif\r257.tif
gp.Copy_Management(r257,J:\DEM_tif\r257.tif)
copying r258 to J:\DEM_tif\r258.tif from G:\02_Shasta\DEM_Tile\
J:\DEM_tif\r258.tif
gp.Copy_Management(r258,J:\DEM_tif\r258.tif)
copying r259 to J:\DEM_tif\r259.tif from G:\02_Shasta\DEM_Tile\
etc...
