how can I upload raster and polygons to a gps unit
2889
6
11-11-2017 01:57 PM
janehansen
Hi I need to be able to upload a raster image and a polygon to a garmin unit.  Does anyone know what conversion tool, if any, is available in arc gis 10.5 that can do this conversion. Or any other method that I can use to create a file that the garmin will recognize.
Jane
DanPatterson_Retired
too many garmin units to comment.  and they appear to have limited alternate upload capabilitys according to a Dr Google search (ie .img for images, but not your standard img.
You will have better luck with tracklogs and waypoints, even from google earth etc
janehansen
Thanks Dan but what I am looking for is how to upload a map that contains
the ortho image and polygons needed to GPS so they can be used to help with
a survey on the ground.
I found a MapToGarminCustomMap
<https://bitbucket.org/wankoelias/maptogarmincustommap>
tool, downloaded it added it to my tool box but it tells me the tool does
not exist.
Any ideas?
Jane
I didn't download the file, but I went to "Source" link to see what was there.
Here is my visual summary
janehansen
Got it to work, thanks for your help Dan
glad it worked out Jane
XanderBakker
Esri Esteemed Contributor
A little over a year ago a client came to me with a similar question to convert some points (about 10.000) into a GPX file. When I asked what the specific purpose was, I started to explain the advantages of using Collector for ArcGIS - Collect & Update Data in the Field | Esri and being able to collect data in a structured way and taking photo's and being able to follow progress of field work by configuring a Esri Software | Operations Dashboard for ArcGIS .
In case your Garmin device has Android OS you probably can install Collector and publish your data in ArcGIS Online: Prepare your data in ArcGIS Desktop—Collector for ArcGIS | ArcGIS
This client is now completing their second validation of all those points in the field and presented at our user conference. You can read more about this here: CCU 2017 - Seguimiento, Monitoreo y Actualización de la compensación forestal de la PTAR Bello - EPM (although it is in Spanish).
So the question is, what do you want to do with your data in the field?
