How can I see my raster?
2121
15
10-07-2020 06:41 PM
CathySmallridge
I am fairly new to ArcGIS Pro so apologies if this is a very basic question.  I am trying to import a map from an ascii file using the Copy Raster function.  I have carried out the operation on several files, and it seems to show that the new rasters are there in the contents pane on the left.  I can change symbology etc.  but I can't see it on my map?  What do I do next please?
CathySmallridge
OK, many thanks Dan.  I'll have a go at that.  Much appreciated.
Mary_Murphy
Hi Cathy - just had a go with some Rainfall ASCII files - and, in the Define Projection tool, used GDA 94 as per their website - and that seems to have worked beautifully i,e. GCS_GDA_1994.
Excelsior.
CathySmallridge
Thanks Mary, I haven't had a chance to get back to it yet, but will have another go.  It is good to know that you have been able to make it work.
CathySmallridge
Thanks Mary.  I was trying to use a "Projected Co-ordinate system", but now that you suggested the Geographic Co-ordinate System, all is well.  Thank you.
Mary_Murphy
No problem at all!
Excelsior.
Ishwar_Vatas
Hey Cathy, I'm doing the exact same subject as you and attempted to follow along all the steps, but couldnt get anywhere, Can you please help me if you were able to find how to project the raster over Australia
