I'm using ArcGIS 10.1 and have a field containing a date and time I need to get the day of the week based on my date field and also when the same field that contains date and time
I need to do this from the field calculator
example
The script above was created to run as stand alone script, but if you have your table in you TOC, you can simply take the code below:
with arcpy.da.UpdateCursor('NombreDeLaTabla', ('Hora__GPS', 'Dia', 'Hora')) as curs:
    for row in curs:
        curs.updateRow((row[0], row[0].weekday() + 1, row[0].strftime('%H'), ))... change the 'NombreDeLaTabla' on the first line into the name of your table, open the Python Window:
... paste the code:
.. and hit Enter.
(Check and change the names of the fields 'Hora__GPS', 'Dia', 'Hora' if your schema is different.)
Kindly go though the link
Code samples—dates section -
Calculate Field examples—Data Management toolbox | ArcGIS for Desktop
over simplified, but you need to do slicing... convert dates to string first
>>> t = "02/02/2016 08:54:11 a.m."
>>> dia = t[:2]
>>> dia
'02'
>>> hora = t.split(" ")[1][:2]
>>> hora
'08'
>>>Which would mean that you would have something like
dia field .... str(!timefieldname!)[:2]
hora .... str(!timefieldname!).split(" ")[1][:2]
or something like that
To bad you have to use the FieldCalculator, because it can be a real challenge to make it work. I tried the samples that Ajitkumar Babar refers to, but for some reason it throws errors like "The value type is incompatible with the field type". Parsing it to string will work, as Dan Patterson suggest, but you will have to account for the AM/PM setting to get the right hour (hora).
I you could use some Python code, then this is how you could do this:
def main():
    import arcpy
    tbl = r'C:\GeoNet\XLSDate\data.gdb\test_tbl2'
    fld_date = 'Hora__GPS'
    fld_dia = 'Dia'
    fld_hora = 'Hora'
    with arcpy.da.UpdateCursor(tbl, (fld_date, fld_dia, fld_hora)) as curs:
        for row in curs:
            fecha = row[0]
            dia = fecha.weekday() + 1
            hora = fecha.strftime('%H')
            curs.updateRow((fecha, dia, hora, ))
if __name__ == '__main__':
    main()Result:
    for row in curs:
... paste the code:
.. and hit Enter.
