Geotransformation is not valid
2747
05-24-2014 09:33 AM
LT
Hi All,
I'm trying to find the area of my Denver, Colorado polygons in kilometers (km) and I think my data is in Decimal Degrees, so I need to project it before using calculate field to calculate the area.
My data properties say the following:
Data Type: Shapefile Feature Class
Shapefile: C:\foo.shp
Geometry Type: Polygon
Coordinates have Z values: No
Coordinates have measures: No
Geographic Coordinate System: GCS_WGS_1984
Datum:  D_WGS_1984
Prime Meridian:  Greenwich
Angular Unit:  Degree
My specific questions are:
  1. I think this means my data is in decimal degrees and I need to project it to get an accurate area measure in km.  Does this sound correct?
  2. I believe an appropriate coordinate system would be:
  3. NAD_1983_HARN_StatePlane_Colorado_Central_FIPS_0502_Feet
    My source of coordinate system selection is from here:
    http://www.denvergov.org/?TabId=426422
    http://www.spatialreference.org/ref/?search=Colorado
  4. The project tool requires a coordinate system transformation and I selected NAD_1983_To_WGS_1984_5.  Does this sound correct?
  5. I based this selection on this source: http://blogs.esri.com/esri/arcgis/2009/05/06/about-geographic-transformations-and-how-to-choose-the-...
    which says:
    HowTo: Determine which NAD_1983_To_WGS_1984 transformation to use--
    NAD_1983_To_WGS_1984_1 �?? for the entire North American continent.
    NAD_1983_To_WGS_1984_2 �?? for the Aleutian islands.
    NAD_1983_To_WGS_1984_3 �?? for Hawai�??i.
    NAD_1983_To_WGS_1984_4 �?? superseded by _5; this transformation method should no longer be used!
    NAD_1983_To_WGS_1984_5 �?? for the 48 contiguous United States.
    NAD_1983_To_WGS_1984_6 �?? for the Canadian province of Quebec.
    NAD_1983_To_WGS_1984_7 �?? for the Canadian province of Saskatchewan.
    NAD_1983_To_WGS_1984_8 �?? for the Canadian province of Alberta.
  6. I get an error when I run the Project (Data Management) tool.
    Here's a picture of how I filled in the Project GUI: http://screencast.com/t/ARKUS3wQdf
    This is the error I get:
    ERROR 000151: The geotransformation(s) is not valid.  Failed to execute (Project).
    Any ideas why this may be happening?
Thank you for your help!
LT
Oops-- I got rid of the error by switching to
NAD_1983_StatePlane_Colorado_Central_FIPS_0502
instead of
So you can ignore question #4.  However my first three questions still remain.
Thanks again.
