Extrac shapes from Geodatabase
414
10-06-2021 10:56 PM
GerardoRTMex
Hello everyone, I am writing to request your support. It happens that I have a Geodatabase with 15000 shapefiles of animal species and as you will know the geodatabase has all the species "united" and displays them in a single shape, I would like to know if you know any tool or way to separate each of these 15000 shapes so that you can see the distributions of these species separately. Tried with the "Feature Class To Shapefile (multiple)" tool in ArcMap but it doesn't separate them. I am using ArcMap. Thank you very much for your support. Greetings to the whole community
Gerard
MehdiPira1
@GerardoRTMex ,
Use "Split By Attributes" in Analysis > Extract toolbox in ArcMap. You need to select your field e.g. species or whatever the field name is as Split Fields to separate the feature class.
https://desktop.arcgis.com/en/arcmap/latest/tools/analysis-toolbox/split-by-attributes.htm
MehdiPira1
@GerardoRTMex ,
