ERROR 000210: Cannot create output in network location - KML to Layer
3872
09-04-2014 11:21 AM
ManikandanKalyanasundaram1
Hi ,
I am trying to convert KML file to layer file and GBD. I need to generate the output in a network location.
I am getting the following error if I give the output location as network location.
Executing: KMLToLayer \\<networkpath>\folder1\gpUpload\GraphicsToKMLExport.kml \\<networkpath>\folder1\gpUpload temp1 NO_GROUNDOVERLAY
Start Time: Thu Sep 04 11:15:16 2014
ERROR 000210: Cannot create output \\<networkpath>\folder1\gpUpload\temp1.gdb
Failed to execute (KMLToLayer).
Failed at Thu Sep 04 11:15:17 2014 (Elapsed Time: 0.29 seconds)
I have read and write access to the shared folder. I am using ArcGIS 10.2.1 version.
Please let me know if there are any workarounds or solutions.
Thanks in Advance,
Mani
Anyone facing this issue ? Is it a bug in the product ?
KoryKramer
Esri Community Moderator
Hi Manikandan,
Did you ever find out what was happening with this error?
Any more information about whether it was solved and how would be appreciated.
Thank you!
