Deviation of the circular area of a buffer
381
03-07-2022 01:44 AM
milla
I have created buffers that I now want to intersect with a layer. My problem is that the area inside the buffer doesn't match the theoretical area for a circle of that radius. I have the same deviation for every buffer. All coordinate systems are the same. The layer I'm using is definitely gapless (I checked that). The buffers that I use for intersecting have the correct area.
I need the correct area in the buffer to be able to continue with my task. Unfortunately I'm clueless.. I would be grateful for ideas and help.
DavidPike
MVP Frequent Contributor
What coordinate system is it in?  Could you provide the observed difference and screenshots also please?
DanPatterson
If the output was to a shapefile, then you have an "ngon", an n-sided replica of a circle since shapefiles don't support true curves (eg a circle) like featureclasses in a geodatabase.
If your coordinate system, is web mercator, then don't use it, use a better planar projected coordinate system.
You should be using a geodesic buffer also
How Buffer (Analysis) works—ArcGIS Pro | Documentation
Buffer (Analysis)—ArcGIS Pro | Documentation
To see if your buffer is a true curve, use
Calculate Geometry Attributes (Data Management)—ArcGIS Pro | Documentation
and calculate Area_geodesic and CURVE_Count to see if the buffers are truly circles rather than n-gons
... sort of retired...
