Deleting first character in field
33223
7
08-25-2016 08:31 AM
steveubert
Hello
I'm running arcmap 10.4. I have 5k entries of 'FEC_IDCODE' with 01234 and I need the first 0 deleted. I have tried to google search and edit various scripts to delete the first letter of a text field. I've tried the codes and advice from the listed websites. All I've gotten is error codes with each try. What am I doing wrong.
arcgis 10.0 - Delete first two letters from a string field - Geographic Information Systems Stack Ex...
qgis - How to remove a certain number of digits from the front or end of an attribute field? - Geogr...
Field Calculator- Delete last 3 text characters
How to remove first character from every row of an attribute field
https://community.esri.com/thread/21358
JoeBorgione
I just tried this and it worked:
Where all my FEC_ID fields had a leading 0....
That should just about do it....
JoeBorgione
steveubert
thank you
JoeBorgione
Happy to help-  would you mind checking my response as answered?
DanPatterson_Retired
done... and a big python check mark too ... sometimes they forget
by Anonymous User
Not applicable
Perfect and simple! Adjusted to remove the first and last characters using the character number count
DominicMarchionna
Thank you! This worked perfect to remove leading two numbers in a field.
DavidCooper
This was a great help to me, thank you so much!
