Create points along the line using predeterminated distances
634
08-07-2018 01:06 PM
CarusoGeo
New Contributor II
Hello!
I have one table with many distance values in meters.
And I have one line feature
I want create points along the line using these distances.
Ex:
Table
1 - 1.6
2 - 3.9
3 - 10.5
4 - 12.7
Thanks!
LeonS
Occasional Contributor III
Check out linear referencing... What is linear referencing?—Help | ArcGIS Desktop
Your line feature(s) will need M-values and a unique id to create routes.  You should then be able to use the Make Route Event Layer tool to generate points off your table.
Leon
CarusoGeo
New Contributor II
But I have only one line (one row). How i supposed create ids and M-values?
DanPatterson_Retired
Densify—Help | ArcGIS Desktop  only allows for equal incrementing.
How many points do you have to add? 10? 100? (ie, manual versus scripting.
Is your line straight? (image would help)
How is your python?
You need to provide some use-case data or the problem is too simple
dist = [1.6, 3.9, 10.5, 12.7]
hence
x = [1.6, 3.9, 10.5, 12.7]
y = [0.0, 0.0,  0.0,  0.0]
Rotate the segment
CarusoGeo
New Contributor II
I created one id field in my only row and works. Thanks!!
