Counter for While iteration in the model builder
2001
11-07-2016 06:04 AM
AlessandroSinglitico
Hi everyone,
I'm using ArcGis 10.3. I am on the model builder and I have a While iteration. What I want to do is to create a counter: a variable x which is initialized with the value 1 and add +1 at every run, so the variable x actually shows the number of run.
This is because I want to use that value for saving data with in-line substitution (...%x%...).
You can see attached my first attempt. Basically  my Continue is a precondition for Calculate value (2) and the code in it is:
Expression: x("%Continue%")
def x(n):
 if n== "true":
  x=x+1
but I got this error:
ERROR 000539: Error running expression: counter("true")
  File "<expression>", line 1, in <module>
  File "<string>", line 3, in counter
UnboundLocalError: local variable 'counter' referenced before assignment
Is there a nicest and easiest way to create a counter?
(Basically the For iteration has it automatically as the Value, but the While lacked of a variable which takes account of the run)
Alessandro
DanPatterson_Retired
The for syntax is here For—Help | ArcGIS for Desktop
and while is here While—Help | ArcGIS for Desktop
and there are other iterators within the list.  The syntax for why requires a set of inputs and whether to loop until the boolean is either True or False, depending on your choice
DuncanHornby
MVP Notable Contributor
You say that Calculate value (2)  has the expression:
def x(n):
 if n== "true":
  x=x+1
But the error message is about counter("true")? You need to show us the whole model or upload it as a zip file as what you are asking is not clear.
Also look at the help file for the subject Examples of in-line variable substitution with ModelBuilder system variables there are two system variables %i% and %n% accessible to you in model builder, may be they are what you are looking for?
Hi Duncan,
Yes I was actually trying to build a counter to use for in-line substitution. It sounds like  the %n% system variable does all the job, there is no need to build anything.
Thank you!
