Clip And Ship can not download
3474
10
10-12-2012 02:46 AM
anjelinaponker
I,m using Clip And Ship but  client can not download output.zip although the output.zip exist in arcgisjob. what should I do?
ShingLin
What kind of client are you using?
anjelinaponker
Hi
My client use flex viewer 3.
Regards
anjelinaponker
Hi
Any solution?
ShingLin
Sorry to get back to you late. Which version of server are you using?
ShingLin
I tried ArcGIS Flex Viewer 3 on 10.1 server and have no problem to download the zip file. How do you set your operational layers and widget for the Viewer.
anjelinaponker
I add a mapservice that contain downloadable layers in my config.xml
The "output.zip" generate in this address:
C:\arcgisserver\directories\MyDefaultFolderjobs\clipandship_gpserver\j3fdde405c46e430f9f04aba3575a9bf5\scratch\scratch.gdb\output.zip
But the widget can not download it in client's browser. is above address ok? what is wrong in my server?
ShingLin
The zip file should be saved under the scratch folder of the arcgisjob, not scratch gdb. That's why you cannot obtain the zip file from the Viewer. Check your model, make sure the output is written to %scratchworkspace%\output.zip, not %scratchgdb%\output.zip.
anjelinaponker
Hi
I checked my model, it has %scratchworkspace%\output.zip
When I run extract widget in my application (flex) and after that I check the arcgisjob directory, there is just an output.zip file in my scratch.gdb folder and original scratch folder has not any output.zip!!!!!, but it has 3 subfolders(scratch.gdb, scratchFolder and ZipFolder).
What is wrong?
JorisBak
Hi
What is wrong?
Try using the default path that is used in the 10.1 extract data tools: %scratchFolder%\output.zip. That solved this issue for me (I also used %scratchworkspace%\output.zip).
