The short answer is that yes, if you change tha path to the .tbx files, the scripts "should" work - provided nothing else prevents the script from working, which is quite likely.
Also, note that you don't have to load any of the system toolboxes (managment, analysis, etc.), just the custom ones. So you could really just delete that line altogether.
