Calculating field values from shp to another
3596
10
02-18-2016 01:29 PM
ScottHoffman1
Afternoon All -
In the picture below there's a Seg ID (blue line) and four purple areas with unique IDs show in purple.
Is it possible spatially add the four unique IDS to a single field within the Seg ID shape file?
I tried spatial join, but it lists the Seg ID multiple times, which doesnt work for what the client needs.
The only way we have been able to achieve the end goal is to manually type in the unique IDS from the purple areas into the a single field with in the Seg ID layer. Sadly this method is extremely time consuming.
Thanks for the help!
roads.tif
ScottHoffman1
bingo! thank you so much!
