Calculating angles using ArcGIS Desktop 10.2
33099
32
01-21-2016 11:17 AM
BrianVann
I need to find angles of streets where they intersect with roadways covering the entire state. Does anyone have a method and/or tools in mind?
WesMiller
Put the below at the top of the script
import arcpy
JeremyMullins4
Wes,
I mentioned in my comment that I tried that and it fixed the first error. However, the second error came up afterwords. I tried changing the paths from 'in_memory' to a file geodatabase and it gave me the same error. I looked through the script provided by ArcGIS for Intersect in the location provided in the error, and I didn't see any syntax issues (obviously, why would there be if it worked for Darren and others...)
I see where in line 289 it gives me an error, but I'm not sure why. Here is what the script says:
from arcpy.geoprocessing._base import gp, gp_fixargs
    from arcpy.arcobjects.arcobjectconversion import convertArcObjectToPythonObject
    try:
        retval = convertArcObjectToPythonObject(gp.SpatialJoin_analysis(*gp_fixargs((target_features, join_features, out_feature_class, join_operation, join_type, field_mapping, match_option, search_radius, distance_field_name), True)))
        return retval
    except Exception, e:
        raise e
I'm trying to figure out why it raised e. I am only using a single polyline feature class to perform this analysis, but I didn't see that as an issue with the Intersect tool. I made sure to replace my lines to the path to the file geodatabase (although I have a feeling it may need to be a shapefile to access the .dbf file???)
DarrenWiens2
Maybe we'll see something if you post the script up to the point where it throws the error.
JeremyMullins4
Darren - you're absolutely right. I should have post that. Apologies. Here it is:
import arcpy
import os
fc = "C:\Users\jmullins\Desktop\GIS Data\Customer Data\Washington County FL\Washington County FL Data\WashingtonCountyFL.gdb\GEO\StreetCenterline"
sr = arcpy.Describe(fc).spatialReference
radius = 50
out_fc = r'in_memory\points'
int_pt = r'in_memory\int_pt'
arcpy.Intersect_analysis(fc,int_pt,output_type='POINT')
DanPatterson_Retired
fc = r"c: etc
  • you need raw notation
  • and you really need to use a much shorter path without spaces.  the max length is 260 characters (filename is different) but yours is really long
  • are rest of the lines used?
I didn't get past there
JeremyMullins4
Thanks so much to everybody for all your help. I was able to make it work! It was two things:
1. Dan - you were absolutely spot-on with the file path. I moved the geodatabase up and made it work. For this tool, I may simply export to a shapefile in a higher-level folder and then reimport back into the original geodatabase. Or I may just have to reorganize all my data, which is probably a good thing considering the issues here.
2. Since this wasn't a shapefile and was a feature class, I made sure to change any tool looking for 'FID' to look for 'OBJECTID', and it worked like a charm. Thanks so much for all the help.
One last question: is there a way to iterate this so that it overwrites files with the same name? I want this to become automated so that a customer could run this script (as part of a much larger model) on a regular basis whenever they want without having to concern themselves with errors about how a shapefile or feature class already exists. If not, I'm sure I can put a 'Delete' option in the model to delete the files afterwards.
Thanks again.
WesMiller
arcpy.OverwriteOutput = True
JeremyMullins4
Thanks Wes - makes sense. Where would I put this line of code? After every instance where an arcpy method is called?
WesMiller
Put it at the top of your script and it will persist. Or to delete a file see below.
import os
svFile = "some file name"
if (os.path.exists(svFile)):
    os.unlink(svFile)
use OIDFieldname all the time, applies to tables as well...saves the hastle for mix of FID and OBJECTID
OIDFieldName = arcpy.Describe(inFeatureClass).OIDFieldName
