Calculate field tool in a geoprocessing service
725
01-21-2013 12:44 AM
ab1
I'm trying to use a geoprocessing service task that contains the calculate field tool.
When I execute the model from ArcMap without using the service, everything goes right.
But when I call the gp task from the rest API, it seems that the calculate field does not work because I get a Null value in the field that should contain a numeric value.
Does calculate field work fine when used in GP service tasks?
Regards
ab1
ab1
