Best and most efficient way to join many tables to a layer in Model Builder
455
06-05-2012 09:13 AM
CharlesBanks1
New Contributor II
I have a polygon featureclass and wish to join several tables to this FC in a model, producing a single layer with all tables. What is the best and most efficient way to go about this? Any ideas?
JonathanQuinn
Esri Notable Contributor
Use the Add Join tool under Data Management Tools > Joins as many times as you need to perform the join, then use the Feature Class to Feature Class tool under Conversion Tools > To Geodatabase, (you can save it as a shapefile or feature class depending on the location), to create a layer that permanently contains those additional fields.  You'll probably have to use the Make Feature Layer tool if you're bringing in a shapefile or feature class as the input Layer Name or Table View.
CharlesBanks1
New Contributor II
Yes, but you would have to use Add Join, say four times (if you have four different tables) in a sequence. Would you not?
