ArcMap 10.3 crashing on polyline merge.
4861
05-04-2015 05:51 AM
BrianBorg1
Merging of poly lines is crashing ArcMap. This issue has been happening since installing arcgis 10.3 with available patches. Consequently we had to revert back to 10.2.  Any feedback will be appreciated.
Thanks
Ian
JayantaPoddar
Hi Brian,
Any other instances of crashing, like when you merge polygons, using union/intersect tool, conversion of KML?
What is the data storage type? Try working in File GDB. If you work in File GDB, does the issue still exist?
Think Location
BrianBorg1
Hi Jayanta.
Arcmap is only crashing when trying to merge polygons and does not crash when using a file GDB.
Our current data is residing on SQL 2008 r2.
Regards
Ian
JayantaPoddar
Hi Brian,
Try disabling the background geoprocessing option. (Geoprocessing > Geoprocessing Options > Background processing. Uncheck "Enable".)
Run the tool again. Is it still crashing?
Think Location
