ArcGIS 10.2.1 for Desktop and Server
2705
12-16-2014 08:51 AM
KrisFoster
New Contributor III
Does anyone else have issues with having both of these installed on the same server.  I had ArcGIS 10.2.1. for Desktop installed and had been running many python scripts for some geoprocessing.  All geoprocessors were working without issues until I installed ArcGIS 10.2.1 for Server.  Now all of the geoprocessors that were running prior no longer work.  Is there something I need to modify in the python scripts to allow them to function on a server with both of these installed?
For example I have a python script that drops fields from many feature classes (arcpy.DeleteField_management).  When I run it from my server with both installed it fails with the following.
"Failed to execute.  Parameters are not valid.
ERROR 000732: Input Table: "TableName" does not exist or is not supported."
If I copy the python script and sde data connection file to another server with only ArcGIS 10.2.1 for Desktop installed it works without issue.  I also have another python script that uses the following:
fcList = arcpy.ListFeatureClasses()
for fc in fcList:
It throws the error:
TypeError: 'Nonetype' object is not iterable.
Again though I can copy the sde connection file and python to another server with only ArcGIS 10.2.1 for Desktop installed and everything works properly.  I have also replicated the python failures on another server that has both installed.
George_Thompson
Esri Frequent Contributor
Hi Kris,
You may want to look at this blog:
Why do Python scripts fail on a machine with both ArcGIS for Server and Desktop installed?
It may have to do with pointing to the 64-bit Python libraries and not the 32-bit libraries.
Hope this helps!
-George
--- George T.
George_Thompson
Hi Kris,
Hope this helps!
-George
--- George T.
KrisFoster
New Contributor III
Nailed it George! Thanks
