Arcgis 10.1 modelbuilder - defining a field name in a expression to be a parameter
5499
11
04-03-2013 10:04 PM
yonatanrubinstein
I was asked if the following can be done in the modelBuilder (I know it's simple in python, but I was asked specifically on the modelBuilder):
The user has a expression in the model:   str(!city_code_int!).zfill(4)  (the "city_code_int" is the field name of an "long"-type field).
he wants to put only the field name "city_code_int" as a parameter in the model (and not the entire expression).
Is it possible to do such a thing in the 10.1 Model Builder?
Thanks in Advance.
ZacharyHart
Honored Contributor
Did you get this solved?
So what I'm hearing then is that we need to have 2 parameters exposed, correct?
yonatanrubinstein
I didn't succeed to solve this, no, so any help will be much appreciated.
yes, 2 parameters need to be exposed - one of them is supposed to be fed into a otherwise constant expression.
Thanks.
