"calculate field" output in ModelBuilder question
1206
6
06-19-2012 04:56 PM
AmyKlug
HI, I have created a model that performs a spatial join between a point layer and a polygon layer (selecting points inside the polygons) and I want to see if their "name" fields match. So I added a field to the spatial join layer and used python code to populate the field with a "yes" if the fields match and "no" if they do not, points outside the polygons have a null. I would next like to select all "yes" values and remove them so I am left with a table containing only "no" and "null" values/points. The only problem is I can't figure out a way to this. I have tried "select layer by attributes" (will only accept output of "calculate field" as a precondition) and "make table query" (empty field values so can't make a query). if i run the model it creates a feature class after "calculate field" is performed but ModelBuilder does not seem to see this until the model has actually run. ideas? i  would like to do this on one step.
DanBoitshoko
Hi Amy,
Insert the "Make Table View" tool before the "select layer by attribute" tool.  Use  the "Copy Rows" tool to save your selection.
Regards,
Dan
AmyKlug
i tried this but i still dont have any values for my fields when using the query builder in "select layer by attributes" ("get unique values" is empty for all fields). I even tried copying in a query into the expression window. ideas??????
JonathanQuinn
Esri Notable Contributor
What about the Select tool?  Try using that tool following the Calculate Field output.  You can use an expression in the tool to satisfy a certain criteria, and features that fall in the criteria are exported to a new feature class.
AmyKlug
does not work either
I think the problem is that you can only use the select features if the layer has actually been created. I noticed that in the links below they add a precodition variable to the "select by attribute" tool but I don't undertand how they create the variable because they don't show what the data looks like/how they created it.
http://webhelp.esri.com/arcgisserver/9.3/java/index.htm#geoprocessing/gp_servi953844009.htm
on page 31 here: www.junipergis.com/index.php/download_file/-/view/62
DanBoitshoko
Do you need to access the field values? Try this query :  "PointName" <> "PolyName" OR "Join_Count" =0. This will return all the points whose "name" field does not match the polygon "name" and also all the points that do not overlap any polygons.
AmyKlug
I found that if I use "make feature layer" right after the spatial join and before adding and calculating field and then typing in a query even though there are no values it does work, and the query "PointName" <> "PolyName" OR "Join_Count" =0 worked great too but I could also type in the values from the calculated field even thought it was empty
EDIT: I did not need to use "select layer by attributes" or add/calculate field because "make feature layer" has a query option and worked with the above query
Thanks Dan!
