Acquire type of day from date field
2571
07-08-2019 07:36 AM
MalcolmLittle
Hello,
I'm trying to fill a new string field with whether it is a "weekend" day or "weekday" day. I have an existing field that has full date-time values like this:
I'm not sure of the Python code needed in Calculate Field. This is what I have so far, but ArcPro rejects it, saying FullDateTime is not defined:
LanceCole
Malcolm,
You are correct on the 0-6 for weekday(), I was thinking of isoweekday() which is 1-7 for Sunday through Saturday.  Sorry about that.
As you already are submitting a date type all you need is weekno = labelday.weekday() in your code to replace weekno = datetime.datetime(lableday).weekday() and you do not need the import statement. Something along the lines of the following using your naming:
def typodate(lableday):
  weekno = lableday.weekday()
  if weekno < 5:
    return "Weekday"
  else:
    return "Weekend"
LanceCole
You need to
1) pass (!FullDateTime!) to your function not (!DayType!)
2) move the "weekno = datetime.datetime(labelday).weekday()" line into your def statement rather than outside.  Another consideration, what type of data is FullDateTime: string, datetime, etc.
3) your first condition should be "weekno <= 5" as 1 through 5 are Monday through Friday.  6 and 7 are Saturday and Sunday for the weekday() function.
MalcolmLittle
Thanks for the quick reply.
I ran it with your changes, yet I get an error "TypeError: an integer is required (got type datetime.datetime)". Perhaps this is because the FullDateTime field is a Date field. Is there a way to evaluate a Date field to acquire the type of day?
LanceCole
Malcolm,
Can you please 1) provide a copy of the revised code and 2) confirm the FullDateTime attribute is a type of datetime and not a string.  You can check this by right clicking on the attribute name in the table and selecting properties or just looking at the field information for the feature.
MalcolmLittle
This is my latest code with error:
This is the Field information regarding FullDateTime:
PS someone told me that datetime treats the days of the week as 0-6 values, starting with Monday at 0.
LanceCole
Malcolm,
  if weekno < 5:
    return "Weekday"
  else:
    return "Weekend"
