I have had a desire to set a switch/flag in geoprocessing scripts that log at a level corresponding to the setting in the server.
The 'Message Level' setting can be accessed using the python api.
I accomplished this via a small function as follows.
from arcgis.gis import GIS
def get_server_loglevel(checkservicename):
infolevel = None """set infolevel to None and handle None separately
or set infolevel to a default - e.g. 'info' """
for folder in servicesdirectory.folders:
folder_services = servicesdirectory.list(folder=folder)
for folderservice in folder_services:
service = folderservice.service
servicename = service.properties.serviceName
if servicename == checkservicename:
# match the service name from the script to the one in the server
if 'showMessages' in service.properties.properties:
infolevel = service.properties.properties.showMessages
return infolevel
# obtain the gis (portal) object
gis = GIS(r'https://fully.qualified.domain.name/portal', 'portaladmin', 'Passw0rd', verify_cert=False)
# call the federated hosting server
federatedserver = gis.admin.servers.get(role="HOSTING_SERVER")[0]
# get the servicesdirectory object.
servicesdirectory = federatedserver.content
serverloglevel = get_server_loglevel(servicename, servicesdirectory)
# use serverloglevel in the script to log accordingly.
The use for this may be a bit unconventional but it has helped to pass control of the 'log level' to the geoprocessing script so log files can also be written based on the server log level.
import logging
general_loglevels = {'Error':'ERROR', 'Warning': 'WARNING', 'Info': 'INFO'}
# https://docs.python.org/3/library/logging.html#logging-levels
if serverloglevel in general_loglevels:
loglevel = general_loglevels[serverloglevel]
else:
loglevel = 'DEBUG'
logger = logging.getLogger("GP Service")
level = logging.getLevelName(loglevel)
logger.setLevel(level)
