GeoDev Meetup topics
3702
10
05-25-2018 05:22 AM
MarkusSchlager1
With this discussion we are collecting topics for the next meetups.
This could be topics you are interested to discuss about as well as topics, where you are able to share know-how, information or lessons learned with other GeoDevs.
As soon as we have a handful of topics we will create a poll, so that you can decide what should come up next.
Please add your topic below!
Adri2cPérez_Beneito
Hi!
As a developer I'm interested in:
- Web App Builder Custom Widgets (ES5, ES6, TypeScript). Some of my developments here
- ArcGIS API for JavaScript 4.X TypeScript Custom Widgets
- ArcPy and the API for Python...
We can share knowledge and special tools for NGO's, for example, no?
MatthiasSchenker
Hi Adri2c Pérez Beneito
Thank You for this input. You can certainly share knowledge and special tools for NGO's through this community since there are many developers in Switzerland who are working on these topics, but I would recommend that you share such content also in the community for Nonprofit and Global Organizations.
It might be best to share your code by linking to an external repo, e.g. on Github, or by sharing the code on ArcGIS Code Sharing and then linking to it.
Have a nice day!
Matthias
Adri2cPérez_Beneito
Hi!
All my custom widgets are on ArcGIS Code Sharing as sample code and my Github, I will prepare an entry here
I will check this NGO group thanks!
Best
A.
AndryJoos
New Contributor III
It was great to meet some of you last week at the GEOSummit 2018. One of the important topics there has been the showcasing and value of AR/VR solutions, of visualization and visual data (including remote sensing). I think it would be great to dive into these topics again, this time with a technical view. I think many of us come up with use cases for AR instantly, and I'm curious to hear and see whether some of these ideas have been implemented, lessons learned, techniques used...
Maybe this could be a topic for the GeoDev Switzerland meetup that we plan to host at our facilities.
MarkusSchlager1
Thanks for your input! AR/VR definitely is a trending topic and we see upcoming real life-scenarios growing in numbers. As our business use case-specialist for this field, Christoph Haeberli‌, what do you think about AR/VR as one of the next GeoDev Meetup-topics?
ChristophHaeberli
Good Idea. We also could bring the newest Infos from the Esri UC. Inviting one of our Partners, who are developing for Hololens, could be another point.
Adri2cPérez_Beneito
Hi all,
You can check the ICRC Web App Builder Custom Widgets repository on Github here! We are releasing some of our Esri developments; creating the widgets with ES6 using Yeoman (compiling the code with Grunt to ES5).
Cheers
MarkusSchlager1
Thanks for sharing!
Maybe we find other Swiss web developers out there, that also want to share their Custom Widgets?!
ChristophSpoerri
New Contributor III
Hi there,
maybe not a hot topic, but one of high importance for devs: how can I write unit tests if I work with Esri SDKs? We often run into problems writing unit codes and need to setup an entire db to test against or the ArcGIS classes can't be mocked at all.
Therefore it would be interesting to find out how others solve that problem or if there's some info on the topic from Esri.
cheers, Chris
