Xquery for searching data inside enterprise GDB in SQL server in XML data type
2695
8
07-14-2016 07:16 AM
Muqit_Zoarder
Dear all, in my sql server GDB i have a table containing XML data type, where i need to search and update a particular element within all the xml files and update it. Can anyone help me please ?
With best regards
Muqit Zoarder
Tags (1)
George_Thompson
Esri Frequent Contributor
Hi Muquit,
That table may be holding the metadata for a feature class. I would not recommend modifying any of the repository tables out side of the ArcGIS tools (i.e. via SQL). Here are some links to more information.
System tables of a geodatabase in SQL Server—Help | ArcGIS for Desktop
SQL Server configuration parameters—Help | ArcGIS for Desktop
--- George T.
Muqit_Zoarder
Hi George, thanks, but how i can find one specific data out of a xml file in documentation field? see the following xml example:
<metadata xml:lang="de">
  <Esri>
    <CreaDate>20160308</CreaDate>
    <CreaTime>11184000</CreaTime>
    <ArcGISFormat>1.0</ArcGISFormat>
    <SyncOnce>FALSE</SyncOnce>
    <DataProperties>
      <itemProps>
        <itemName Sync="TRUE">LTFX.DBO.SeehausenPolygone</itemName>
        <imsContentType Sync="TRUE">002</imsContentType>
        <itemLocation>
          <linkage Sync="TRUE">Server=192.168.224.15; Service=sde:sqlserver:192.168.224.15\BONARES,1433; Database=LTFX; User=vasilakakis; Version=dbo.DEFAULT</linkage>
          <protocol Sync="TRUE">ArcSDE Connection</protocol>
        </itemLocation>
Can you please give me an example query? I want to search one xml file according to any element name like itemName
thanks
regards
Muqit
George_Thompson
I do not have an example for a query for extracting the XML tag that you are looking for.
--- George T.
ChristianWells
If you know the path, you can use the value function to gather the values:
SELECT GDB_ITEMS.NAME                                                   AS "FC_Name",
  DEFINITION.value('(/DEFeatureClassInfo/Versioned)[1]', 'varchar(20)') AS "Versioned",
  GDB_ITEMTYPES.NAME                                                    AS "GDB_Type"
FROM SDE.GDB_ITEMS
INNER JOIN SDE.GDB_ITEMTYPES
ON SDE.GDB_ITEMS.TYPE         = SDE.GDB_ITEMTYPES.UUID
WHERE SDE.GDB_ITEMTYPES.NAME IN ('Feature Class','Table')
However, as George Thompson​ stated, please don't make any changes to the GDB repository XML tables.
ChristianWells
Muqit Zoarder​ if this sample is helpful, please mark the post as answered.
Muqit_Zoarder
I need another help, can you please tell me if I make my enterprise GDB by using dbo but not with sde instance then it is a problem ? And what are the main differences?
Regards
George_Thompson
Hi Muqit,
Here some documentation that talks about the differences of DBO vs. SDE geodatabases: A comparison of geodatabase owners in SQL Server—Help | ArcGIS for Desktop
--- George T.
ChristianWells
In addition to George's help, this new question should be attached to a different thread so others using GeoNet for help can see this new topic.
