Wep Map Viewer
1746
10
07-11-2021 05:01 AM
HamzaM
New Contributor III
I want to connect a database to web map viewer but when add the file it only uses the data imported at that time if i edit the file or add more data to it, i have to import it again manually, is there a way to have the data updated automatically and visualized on the map based on the parameters i have already set?
@ColinWerle1 @VinceAngelo @Robert_LeClair Can any of you help?
HamzaM
New Contributor III
I think it will take me a while to figure this one out, but will definitely give it a try.
Thanks a lot for your effort.
