Upgrade Geodatabase issue
601
5
01-31-2018 03:16 PM
PawelGanczarski
Hi everyone,
I am attempting to Upgrade Geodatabase and the following error prevents the upgrade.
"Connected RDBMS instance is not setup for ST_GEOMETRY configuration.You must copy the latest ST_GEOMETRY library to the PostgreSQL software location"
The GDB was created a couple of years ago using ArcMap 10.3.1,  very recently ArcMap was upgraded to 10.6
PostgreSQL 9.3.5 is running on Windows Server 2012 R2
The original st_geometry file exists in PostgreSQL lib folder.  Since the error message suggests the latest ST_GEOMETRY file needs to be copied, I've tried copying the files from DataSupport folder in Postgres 9.4, 9.5, 9.6 but that wouldn't even allow connections to be made.
Also the libeay32.dll, libpg.dll,libintl-8.dll and ssleay32.dll files are in the intended location.
Any ideas any help will be much appreciated
Best regards,
Pawel
Asrujit_SenGupta
MVP Regular Contributor
You did kind off answer the question yourself..
As you can see, the ArcGIS 10.6 Database Support does not have any 9.3 folder. The reason being, PostgreSQL 9.3.x is not a supported database for ArcGIS 10.6.
PostgreSQL database requirements for ArcGIS 10.6—System Requirements | ArcGIS Desktop
To upgrade any further than 10.3.x, you will have to upgrade the version of PostgreSQL.
PostgreSQL database requirements for ArcGIS 10.4.x—System Requirements | ArcGIS Desktop  (Needs atleast PostgreSQL 9.3.10)
PostgreSQL database requirements for ArcGIS 10.5.x—System Requirements | ArcGIS Desktop  (Needs atleast PostgreSQL 9.3.13)
Asrujit_SenGupta
PawelGanczarski
Thanks Asrujit, somehow I managed to miss this important piece of the puzzle.
Hopefully won't encounter any snags during the Postgres upgrade.
George_Thompson
Esri Frequent Contributor
Make sure that you have Visual Studio VC++ 2017 installed on the Windows PostgreSQL server:
For PostgreSQL on Windows, you'll need the latest Visual Studio VC++ 2017 installed on the PostgreSQL instance machine. See https://support.microsoft.com/en-us/help/2977003/the-latest-supported-visual-c-downloads for more information.
--- George T.
PawelGanczarski
Thanks for the tip, George.
Arturo_FranciscoAcosta_Bazán
have been trying to create a GDB on Postgres, copying st_geometry (C: \ Program Files \ PostgreSQL \ 9.6 \ lib) and I got an error from library latest. The solution was to install VC ++ 2017  Thanks George
