Unable to publish spatial view on arcgis server 10.4
1100
12-26-2017 03:09 AM
SriHarsha
New Contributor III
We are able to publish feature class as a map service but we are unable to publish spatial view on server.
I am using env...
ArcGIS server 10.4.1 Advanced
ArcGIS Desktop 10.4.1 Standard
MS SQL Server 2014
GP Results from ArcMap for both cases
View
____
Start Time: Tue Dec 26 15:46:24 2017
Validating publish options.
Connecting to the server.
Getting basic item metadata for service definition upload.
Getting server information (server folders, data stores, etc.).
Extracting manifiest from uploaded service definition.
Deriving arcgis server service from hosted service (hosted service definition).
Updating state based on configuration overwrite.
Validating service definition.
Determining service's input folder name.
Attempt to find service's input folder.
Creating the service.
ERROR 001369: Failed to create the service.
Failed to execute (Publish Service Definition).
Failed at Tue Dec 26 15:46:24 2017 (Elapsed Time: 0.04 seconds)
Failed.
ERROR: the server's publishing job didn't succeed.
Failed to execute (UploadServiceDefinition).
Failed at Tue Dec 26 15:46:24 2017 (Elapsed Time: 1.08 seconds)
FC
______
Start Time: Tue Dec 26 16:05:28 2017
Adding item information card to service.
Updating file and folder information in service's manifest.
Updating database information in service's manifest.
Adding manifest to configuration store.
Building the service URLs.
Succeeded at Tue Dec 26 16:05:40 2017 (Elapsed Time: 11.97 seconds)
Succeeded.
Succeeded at Tue Dec 26 16:05:41 2017 (Elapsed Time: 13.98 seconds)
RexRobichaux2
Occasional Contributor II
Hello Sriharsha,
  If you are still encountering this behavior- can you verify what patches and updates have been installed on your 10.4.1 Server? You can check for available patches thru the utility available with 10.4.x Server
Start->All Programs->ArcGIS->ArcGIS 10.4.x for Server->Check for updates...
Which will show what you have installed, and what else is available, for example
I'd recommend installing the 10.4.1 for Server publishing patch (2) as well as any of the 10.4.1 SQL Server patches that are available if not already installed:
Esri Support 10.4 (10.4.1) = Publishing Patch 2
Esri Support 10.4 (10.4.1) = SQL Quality Improvement patch
Hopefully, these might resolve the issue for you. Does the spatial view display, query, etc. without issue in ArcGIS Desktop?
JayantaPoddar
MVP Esteemed Contributor
A probable solution is discussed here
1) use ArcMap to publish the service with the Feature Access capability enabled, but limited to the Query operation. That successfully publishes.
2) once published, use the ArcGIS Server Manager web app to change the Feature Access operations to include Create, Update, Delete.
Thus, while publishing, only enable Query operation. The rest of the operations can be enabled once the service is published.
Think Location
SriHarsha
New Contributor III
hi Jayanta thank for quick reply, I just trying to publish as map service..even though it is not publishing... showing publishing in progress...
RexRobichaux2
Hello Sriharsha,
SriHarsha
New Contributor III
Thank you Rex, I gone through the above patch implementation. After updating the patch I issue was resolved and there is no such issues on spatial view display, query ,etc over the ArcGIS Desktop also... thanks again... Rex.
