Unable to edit SDE after upgrade to 10.6.1
987
05-17-2019 03:39 PM
Brian_McLeer
MVP Regular Contributor
We updated one of our SDE editor's computers from 10.3.1 to 10.6.1 (ArcGIS Server SDE at 10.3.1). I am able to edit on their 10.6.1 computer, but when they go to edit the same data they get the red warning 'No Editable Layers' with a warning for each layer 'Check to see that you have the appropriate permissions'. We have tested numerous machines both on Windows 8 and 10. We had that user edit the same data on ArcMap 10.3.1 and they were able to edit.
Asrujit_SenGupta
Similar issue - Cannot edit SDE in ArcMap 10.6.1 ?
  • Is this happening with only 1 editor?
  • Is this happening with only a particular database?
  • Have you tried re-granting all the permissions and checked if that helped?
  • If the user is just an Editor, and doesn't own any data-- have you tried dropping that user from the database and re-creating the user? Does that help?
