Trying to remove a featureclass layer in PGDB, then copy a FGDB layer back to the PGDB.
2471
10-02-2014 11:31 PM
Here is the VB.NET code;
        Dim strfcname As String = ""
        Dim GP As Geoprocessor
        Dim CopyFeatures As ESRI.ArcGIS.DataManagementTools.CopyFeatures
        Dim DeleteLayer As ESRI.ArcGIS.DataManagementTools.Delete
        Dim ITrack As ESRI.ArcGIS.esriSystem.ITrackCancel = Nothing
        Dim copied As Integer = 0
                        strfcname = row("FCNAME").ToString
                        LogDetails("Append " & strfcname & " from Mobile Server FGDB to " & PersonalGeodatbaseName & "\Geographics_GDA94_srid5\" & strfcname)
                        GP = New Geoprocessor
                        GP.OverwriteOutput = True
                        Try
                            LogDetails("Deleting  " & strfcname & " from " & PersonalGeodatbaseName)
                            DeleteLayer = New ESRI.ArcGIS.DataManagementTools.Delete()
                            DeleteLayer.in_data = PersonalGeodatbaseName & "\Geographics_GDA94_srid5\" & strfcname
                            'DeleteLayer.data_type = ""
                            'DeleteLayer.out_results = ""
                            RunTool(GP, DeleteLayer, ITrack)
                            LogDetails("Delete of " & strfcname & " from " & PersonalGeodatbaseName & " completed")
                        Catch ex As Exception
                            Return False
                            LogDetails("Error trying to delete " & strfcname & " - " & ex.Message)
                        End Try
                        Try
                            LogDetails("Copying  " & strfcname & " to " & PersonalGeodatbaseName)
                            CopyFeatures = New ESRI.ArcGIS.DataManagementTools.CopyFeatures()
                            CopyFeatures.in_features = strfcname
                            CopyFeatures.out_feature_class = PersonalGeodatbaseName & "\Geographics_GDA94_srid5\" & strfcname
                            'CopyFeatures.config_keyword = ""
                            'CopyFeatures.spatial_grid_1 = 0
                            'CopyFeatures.spatial_grid_2 = 0
                            'CopyFeatures.spatial_grid_3 = 0
                            RunTool(GP, CopyFeatures, ITrack)
                            LogDetails("Copying of " & strfcname & " to " & PersonalGeodatbaseName & " completed")
                            copied = copied + 1
                            Return False
                            LogDetails("Error trying to copy " & strfcname & " - " & ex.Message)
                        End Try
I keep getting this error when ever I try using the Geoprocessor;
Error HRESULT E_FAIL has been returned from a call to a COM component.
I am using Visual Studio 2010 - .Net Framework 3.5 - AnyCPU - ArcGIS Desktop 10.2.1 (Product Version: 10.2.1.3497)
With the standard RunTool;
Public Sub RunTool(ByVal geoprocessor As Geoprocessor, ByVal process As IGPProcess, ByVal TC As ITrackCancel)
        ' Set the overwrite output option to true
        geoprocessor.OverwriteOutput = True
        Try
            geoprocessor.Execute(process, Nothing)
            ReturnMessages(geoprocessor)
        Catch err As Exception
            LogDetails("**Error Executing Geoprocessor for " & process.ToolboxName & " - " & err.Message)
        End Try
    End Sub
    Public Sub ReturnMessages(ByVal gp As Geoprocessor)
        ' Print out the messages from tool executions
        Dim Count As Integer
        If gp.MessageCount > 0 Then
            For Count = 0 To gp.MessageCount - 1
                If Count = gp.MessageCount - 1 Then
                    LogDetails(gp.GetMessage(Count))
                End If
        End If
    End Sub
Reply
