I have upgraded the DB from oracle 11.2.0.1 to 11.2.0.4.
the GDB version is 10.1
How can I get the Compatability of Oracle releases with ArcSDE 10.1
and is it compatabile?
can I enable a new updated version of Enterprise geodatabase, I have License of 10.7.1
If you are using ArcMap 10.7.x, then it may not be compatible; Client and geodatabase compatibility—ArcGIS Help | Documentation
If you are trying to upgrade to 10.7.x, I would recommend installing ArcMap 10.5.1 then upgrade the Oracle EGDB. Once that is completed and verified, I would use the 10.7.x client to upgrade to that version.
The "oldest" supported version is currently 10.3.x; Esri Support ArcMap 10.8
