This release of the Geodatabase is either invalid or out of date
14718
18
10-13-2017 08:00 AM
ElsitMandal1
After getting SQL server management studio installed on desktop, getting error while trying to connect to geodatabases on SQL server 2012. ArcGIS 10.4.1  Appreciate any help!
Asrujit_SenGupta
Unless you are using the exact same configuration as the Original Poster, I suggest you create a new Post with details of your environment.
wilcow
I'm seeing the same error after restoring the DB from a BAK of a different DB.
DB Connection tool can see the DB but throws the error when I attempt to connect.
George_Thompson
Esri Notable Contributor
Did you change the name of the DB during the restore process?
--- George T.
wilcow
no sir the DB name is the same - we restored it to a BAK from a DB with a different name, though
George_Thompson
So you had an "empty / existing" DB then restored the .bak to that one, correct?
If so, that would cause the issue. If you restored the .bak to another DB with a different name it would break things. The only way I have seen a successful restore is to run the process and do not touch anything with the naming part.
--- George T.
wilcow
Yessir. we restored our TEST DB (named test_mwa) using a backup of our PROD DB (named mwa).
This was an attempt to bring the 2 back into sync
George_Thompson
Ok, that is what broke. You have to restore the test_mwa to the same name.
As a test, if you restore test_mwa to the a different instance and leave the name the same, re-sync logins, can you connect then?
I do know that we are looking into allowing you to change the DB name in SQL Server, not sure when it will be available. As I understand it that there will be some version restrictions with renaming it, i.e. must use versions x.x.x or newer clients (ArcGIS Pro, ArcGIS Enterprise, ArcGIS Server, etc.)
--- George T.
wilcow
well, thanks for the info. the restore was required by a 3rd party software that runs stored procedures to update a couple of tables - that process was working fine in PROD and we wanted to replicate to give them a test environment
PaulCyr1
Has this been fixed or a work around found yet? We also restored an enterprise geodatabase with a different name for a test DEV environment and are experiencing the same issue.
