Synchronize Replica Failed - Cannot Insert Duplicate Key Row in Object
662
09-26-2017 01:26 PM
LeviRoberts
I recently started getting the following error:
I've made no changes to my data that I can think of and I can't find any reference online to this error. Anyone have some resources to point me towards?
GIS_Solutions
Occasional Contributor II
i have a smilar problem, How was did you solved this problem?
BirajaNayak
Hi Levi,
We have seen this error before with spatial index corruption.
Try following workflow:
1. In SQL Server Management Studio, run the below query as "dbo" or "sa" user to find the Object_id of the problematic feature class.
select * from sys.indexes where name = ‘S4717_idx’;
2. Then use object_id to identify the feature class:
 select * from sys.objects where OBJECT_ID= 'xxxxx';
3. Rebuild the spatial index for that feature class.
Biraja
