ST_Geometry function is invalid.
1408
01-31-2019 06:07 AM
anilkumar
While running the query on oracle geodatabase, with SQL as sde user, I'm receiving the following Error.
select sde.ST_AsText(SDE.ST_Geometry('POINT(10,10)',0)) from dual;
ERROR:
ORA-20010: Invalid Geometry text dimension. "POINT("
ORA-06512: at "SDE.ST_GEOM_UTIL", line 250
ORA-06512: at "SDE.ST_GEOMETRY", line 20
no rows selected.
I was getting the successful result earlier and no clue about the change happened.
Release 11.2.0.1.0
Any Ideas , on what can cause this problem ?
Regards,
JoshuaBixby
The following is invalid WKT:
POINT(10,10)
Remove the comma separator.
JoshuaBixby
POINT(10,10)
