SDE Database
2811
10-22-2015 09:03 AM
ShannonSmith
I recovered a SQL arcsde database from a year ago so that i can retrieve some information from it. In the last year we have updated SDE from 10.0 to 10.3. I can see my database with no problems in SQL but when i try to connect to it in arccatalog i get the following error message. Failed to connect to database. No ArcGIS server license found. How do i give it the server license. i have tried the Enable Enterprise Geodatbase toolbox and it does not like the database connection.
JakeSkinner
Esri Esteemed Contributor
Hi Shannon,
You will want to connect to the geodatabase as the owner of the SDE repository.  For example, if the repository is owned by the user 'SDE', make your connection with this user.  You should then be presented with a pop-up requesting a license file.
You can then specify an ECP or PRVC file.  If you do not have these, but have ArcGIS Server installed on a server, browse to the C:\Program Files\ESRI\License10.3\sysgen folder on that server and choose the keycodes file located there.
JakeSkinner
Hi Shannon,
ShannonSmith
Thank you thank you. I was connected not as 'SDE' user and as soon as i did that, bam. it all works like magic. I am so grateful for your help!!
ChrisDonohue__GISP
MVP Alum
Adding some ESRI folks knowledgeable in Enterprise Geodatabases (SDE) in case they have ideas to add:
Asrujit SenGupta
Jake Skinner
Vince Angelo
EDIT - Jake replied while I was typing this up
Chris Donohue, GISP
