Register geodatabase table - how to choose the right entity types
3925
5
12-04-2015 05:23 AM
YvesThibault
I'm not and expert with the geodatabase concept.
I need to register geodatabase tables.  So, I will use the "sdetable -o register" and "sdelayer -o register" commands.
In my geodatabase, I have different entity types like simple line(l), point (p), annotation (A) and polygon (????).
When I look at the help of the register command (http://help.arcgis.com/en/geodatabase/10.0/admin_cmds/support_files/datamgmt/sdelayer.htm), I'm not sure with entity type I have to select for the polygon.  As I understand, we can have a combinaison of more than one entity type (like -e nac+).
Does anybody know which entiy type I must use for polygon ?  Do you know how to determine the right entity type?
Thank's in advance!
Yves
ChristianWells
Hi Yves,
In a polygon for example you might use "nac+" which stands for:
n: nil (null geometry allowed)
a: area (REQUIRED)
c: cad (Allows for storing curves)
+: multipart features
You will always need to specify it as and area type, but the others are optional.
What storage type are you using? ST_GEOMETY, SDO_GEOMETRY?
ChristianWells
Hi Yves,
a: area (REQUIRED)
YvesThibault
Hi Christian,
We use ST_GEOMETRY ...
ChristianWells
Thanks Yves, with that response, I don't have anything to add to my statements above. I would mention that equivalent to creating a polygon in ArcCatalog would be "nac+"
YvesThibault
Thank you very much Christian!
VinceAngelo
Esri Esteemed Contributor
For the record,
  • Point feature classes are "npc"
  • Multipoint feature classes are "npc+",
  • Polyline feature classes are "nlsc+", and
  • Polygon feature classes are "nac+"
3-D (well, 2.5-D -- X/Y with Z) would add "3" and measured shapes add "M" (any order).
Geodatabase annotation isn't a separate topology class in enterprise geodatabases; I wouldn't recommend using the deprecated command-line tools to interact with them.
The documentation can be found in many places, including here​.
- V
