Re: Objects in this class cannot be updated outside an edit session
4317
03-02-2021 01:14 AM
ShahriarRahman
New Contributor III
Hi All,
I have defined the workspace, started and stopped the edit session, but afterwards, I am getting the Runtime Error (Objects in this class cannot be updated outside an edit session). The layer "CGD. ROAD_LOCATIONS" is versioned.
……….Script (part)……………..
arcpy.env.workspace = r"\\Pas215q4\User Connection\GS-0001.database.windows.net(1).sde"
edit = arcpy.da.Editor(arcpy.env.workspace)
if (edit.isEditing!='True'):
    edit.startEditing(True, True)
    edit.startOperation()
   field = ['SECTION_ID']
   found_values = defaultdict(set)
   with arcpy.da.UpdateCursor("CGD.ROAD_LOCATIONS", field, "[OBJECTID] > 944861") as cursor:
       for row in cursor:
         for i, column in enumerate(field):
           if row[i] in found_values[column]:
            cursor.deleteRow()
            break
         else:
            for column, value in zip(field, row):
            found_values[column].add(value)
   edit.stopOperation()
   edit.stopEditing(True)
When running this it breaks in (“for row in cursor”), and I am getting the following error message,
………..Error message…………
  File "P:\Create_Assets.py", line 152, in <module>
    main()
  File " P:\Create_Assets.py", line 52, in main
    for row in cursor:
RuntimeError: Objects in this class cannot be updated outside an edit session [CGD. ROAD_LOCATIONS]
No issue with the indentation, maybe I have missed the proper indent here as I am typing it manually. No issue with the script while running from the admin account, but other user accounts is experiencing the run-time issue.
Great to have your suggestions on how to solve this issue please.
Kind regards,
Shahriar
JoshuaBixby
MVP Esteemed Contributor
The following,
strongly indicates there is a permissions issue happening, whether by design or a defect.
If non-admin users try the workflow manually in the application, do they get the same error?
ShahriarRahman
New Contributor III
Hi Joshua,
If non-admin users try the workflow manually in the application, do they get the same error? Yes.
The users have full access to the .sde feature class ("CGD.ROAD_LOCATIONS") and versioning completed. So, I believe there is little chance of permission issue. Do you think there might be some other reasons?
Shahriar
JoshuaBixby
If it works for admin users and not regular users whether using ArcPy or the GUI, it is permissions related.  The question is whether there is a workflow issue or defect.  Without knowing a bit more about the overall workflow, e.g., versioning steps before you get to the functional code part above, I can't offer much on that front.  I would suggest you have your DBA look at the database logs because there may be errors showing up there that could point you in the right direction.
KatyFlaherty
Hello Joshua,
I hit this same error code: ERROR 160250: Objects in this class cannot be updated outside an edit session
As opposed to using arcpy.da.Editor, I found
with arcpy.EnvManager(scratchWorkspace=r"workspace path",workspace=r"workspace path"):
     run functions
solved the errors, I tried this without defining the admin login as well.
Scratch Workspace (Environment setting)—ArcGIS Pro | Documentation
I can elaborate, but see if this works
