Prune Branch History not deleting records.
633
11
10-06-2025 02:36 PM
Labels (3)
BGEGIS
Hello everyone!
The tool in question: Prune Branch History (Data Management)
Versions:
Pro - 3.5.3
Server - 11.5.0
Trying to use the Prune Branch History tool to remove test data from a dataset. This inspections table is related to a feature that is part of a Utility Network dataset. The inspection table and the Utility Network were published as a group and are housed in the same SDE. All test Inspections have been deleted from all versions.
When running the tool there are no errors displayed, but the records are still contained in the archive table. In fact, the logs read as below when selecting the different options available.
REPORT ONLY LOG
[10/6/2025 2:39:17 PM] Prune moment: 10/6/2025 7:39:16.980 PM
[10/6/2025 2:39:17 PM] Reporting how many rows would be pruned from each table.
[10/6/2025 2:39:17 PM] Would prune 22 rows from MUD.ABClient_Inspections_Table
[10/6/2025 2:39:20 PM] Would prune 2 rows from MUD.ABClient_Inspections_Table__ATTACH
ONLY PRUNE SYSTEM TABLES LOG
[10/6/2025 2:42:52 PM] Prune moment: 10/6/2025 7:42:52.283 PM
BOTH
[10/6/2025 2:41:16 PM] Prune moment: 10/6/2025 7:41:15.733 PM
[10/6/2025 2:41:16 PM] Reporting how many rows would be pruned from each table.
There is a view that returns only the most recent Inspection Record for each point that is causing the issues for me. In this view I can still see all records including deleted records. I have tried filtering out the table by the GDB_IS_DELETE, but not all of the deleted records have GDB_IS_DELETE = 1 (some are 0). My current fix is janky at best and is just filtering out the deleted records from the view using GDB_ARCHIVE_OID > xy.
Here is a list of the archive table fields and their contents:
GDB_ARCHIVE_OID - OIDs (current work around is to filter lowest values out)
GDB_FROM_DATE - Date/Times (All have values)
GDB_IS_DELETE - Not all deleted records match, there is a mix of 0s and 1s
GDB_BRANCH_ID - all equal 0
GDB_DELETED_AT - some have the time/date some are null
GDB_DELETED_BY - some have the usernames some are null
Maybe it is a problem with how the table was triggered when the deleted occurred because all of the "GDB_IS_DELETE", "GDB_DELETED_AT", and the "GDB_DELETED_BY" should have values that are exactly the same.
Thanks so much for looking into this with me!!
Esri Community posting of a similar issue -
Solved: Prune Branch History Not Working - Esri Community
How can I prune a Branch Versioned featureclass? - Esri Community
Best,
Scott F
Tags (3)
BGEGIS
Thanks for your message! I will look into the documentation you provided. Let me answer some of your comments.
All versions were reconciled before original post.
The view I am referencing is working for all purposes except for the deleted records are shown. I will look into your documentation to ensure it is set up properly.
My work around to filter by the Archive OID is working. The view functions properly on field maps, AGO, and Pro.
Not all deleted records show the same values in the GDB_IS_DELETEGDB_DELETED_AT, and GDB_DELETED_BY fields. Some have the correct boolean/time/date/username and some are <null> or the incorrect boolean. This is why I think there is a problem with the delete trigger with the archive table.
I will look into the view set up process to confirm it is set up properly, but what I said in the last paragraph is giving me nightmares. Please don't ignore that part. 😅
George_Thompson
Esri Notable Contributor
Here is blog related to this that was just released: https://www.esri.com/arcgis-blog/products/arcgis-pro/data-management/prune-like-a-pro-introduction-t...
--- George T.
