Oracle: upgrade libst_shapelib.so or the geodatabase version (10,7 to 11.0) first?
1619
01-19-2023 12:49 AM
JamesMorrison1
Hello Fellow EGDB'ers.
Current environment:
Geodatabase 10.7.1
ArcGIS Pro 2.9.4
Oracle 18.6.0.0
ST_GEOMETRY
Windows
We move from Windows to Oracle Linux 8
The IT Department have made a copy of the database to the Linux Database Server. So this is running Geodatabase 10.7.1 on Oracle 19.16.0.0
The next step is to
  1. load the libst_shapelib.so file (download the latest versions from ESRI, ArcGISPro_30_ST_Geometry_Oracle) to to the LINUX machine > CREATE OR REPLACE LIBRARY sde.st_shapelib AS > ALTER PACKAGE sde.st_geometry_shapelib_pkg COMPILE
  2.  upgrade the geodatabase from 10.7.1 to 11.0
Question: does it matter if we do 1) or 2) first to reach our goal environment goal Environment below?
Geodatabase 11.0
ArcGIS Pro 3.0.1
Oracle 19.16.0.0
ST_GEOMETRY
Linux x86 64-bit
Thanks for the feedback. Much appreciated.
George_Thompson
Esri Notable Contributor
Looks like you should do #1 first, then #2. See step 7 in this doc: https://pro.arcgis.com/en/pro-app/latest/help/data/geodatabases/manage-oracle/upgrade-geodatabase-or...
Hope that helps!
--- George T.
George_Thompson
Hope that helps!
--- George T.
JamesMorrison1
Thanks George - appreciated.
