Not able to set workspace using standalone Python script for ArcGIS
4859
28
08-21-2018 11:51 PM
HarshalGharat
I am facing a very weird issue in setting the workspace. When I setup the workspace inside python window in ArcMap/ArcCatalog, it just works fine. But the moment I do the same in a standalone python script, the things do not work at all. I tried other options like creating connection file in scratch folder and then setting it as a workspace but still no luck. I am facing this issue on ArcGIS Desktop 10.2.1 and my database is 64 bit Oracle.
I had ArcGIS Pro 2.1 installed on the same machine hence I also tried the same thing after uninstalling ArcGIS Pro but still no luck.
NeilAyres
MVP Alum
Can you browse the database in ArcCatalog once you have opened the connection file?
Just setting env.workspace = "my connection file.sde" has always worked for me.
What happens?
HarshalGharat
Hi Neil,
Yes, I can browse the database in ArcCatalog/ArcMap and walk around the featureclasses/datasets etc. But this is driving me crazy as env.workspace = "my connection file.sde" is no way working for me.
NeilAyres
MVP Alum
What happens when you set env.workspace = "my connection file.sde" in your python script?
Are you using os.path.join() to construct the path pointer to the connection file? Or just raw strings.
HarshalGharat
I set up my workspace in the following manner
arcpy.env.workspace = r"Database Connections\Connection to sde.sde"
# Just for sake of testing, I am trying to print all the datasets
print arcpy.ListDatasets()
The above code snippet prints all the datasets list if I run it in python window withing ArcMap but If I try to run the same snippet in a script, it Print "None"
DanPatterson_Retired
in a standalone script it will need more information that provided since the script has no information as to where the project is.  Can you use a full path to your database connection
Create Database Connection—Data Management toolbox | ArcGIS Desktop
HarshalGharat
Hi Dan,
Thanks for the suggestion. I have tried that option as well and it didn't work.
NeilAyres
MVP Alum
This is not going to work:
The script has no idea where your user profile will be.
Copy the full path as Joe suggests.
Or copy the sde file to a local space and use that.
HarshalGharat
I have tried with full path as well, no luck!
JoeBorgione
Let's see exactly what your are using.
