No data in database view of versioned feature class
584
08-29-2019 01:29 PM
ChrisWiebke
If I have a view of versioned data how do i get the view to return data before the feature class it references is reconciled with the default version of the geodatabase?
George_Thompson
Esri Frequent Contributor
You need to be set the version that you want to see in the view; Read versioned data in SQL Server using versioned views—Help | ArcGIS Desktop
That should get you what you want.
--- George T.
ChrisWiebke
I am able to do that in a ssms query window, but the view I created always reads from default.  I would like to be able to specify which version of the geodatabase the view reads from.  Thanks.
George_Thompson
You need to create a view in SSMS and put that SQL to change the version in the view.
--- George T.
ChrisWiebke
I used this to create the view:
USE [Our Database]
GO
EXEC database.sde.set_current_version 'the version'
/****** view info******/
SET ANSI_NULLS ON
GO
SET QUOTED_IDENTIFIER ON
GO‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
but when I script out the view to a new query window, the exec is not there:
USE [Our Database]
GO
SET ANSI_NULLS ON
GO
GO‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
is there something else I need to do?
Thanks.
